Mystery wood from Peppermill
phinds
Cortland, NY
Paul
@Mr. Peet
Not sure if this pic will work, but let me know if you can ID it
Uh ... good luck with that. Mark sometimes surprises me but that vague, low-res pic is hardly likely to be definitive enough to ID. Can you clean up the surface more and get a more focused image?
Mr. Peet
I was thinking maple, not sure red versus sugar, but also consider yellow and black birch in that order. I discount other maples based on size and species availability and other birches for similar reasons along with spalt pattern.
As Paul stated, clean it up some and maybe....
phinds
Cortland, NY
Paul
I was thinking maple ...
Mark, aren't those awfully strong rays for maple? I ruled out maple based on that. Of course, given the crap quality of the image, maybe what I'm seeing isn't even rays.
Maverick
Las Vegas
That was a fresh cut, but did not sand it. I will put some sandpaper to it and see if I can get a better pic this evening.
Mr. Peet
Thought they were saw kerf lines versus rays...
Maverick
Las Vegas
Ok, let’s try again. Sanded to 220. Let me know if this one will work.
Maverick
Las Vegas
Here is one more that I took outside and did some editing to try and make it better. Don’t know if I succeeded.
phinds
Cortland, NY
Paul
Better. Those lines I was seeing must have been, as Mark surmised, saw kerf lines. The new pics do look like it could well be maple.
