Reel seat inserts (spacers)
Mike Hill
Board Whoarder
Nashville, TN
Kinda like the tarnished look. Would be sorta like the - I think Winston made them or maybe Bellinger - the titanium seats - sorta smokey looking. I think there are some "dark nickel" finished ones available now that would be similar. Used to tarnish - we eat with silver tableware, and my wife used to buy and sell a lot of silver/sterling and has quite the number of silver trophies as a collection. My only concerns with the sterling would be whether it would be too soft and how to make the threads. All I have is a small Sherline lathe - not even sure it has thread-cutting capabilities - probably doesn't. I think I've got some square wire I could curl and solder on.
2feathers Creative Making
Crossville Tennessee
Frank
Sterling usually isn't too hard to shape. Have you thought of using existing steel threaded parts to shape the silver parts? I would guess you have a few standard rods you could use for patterning.
  • #63
Or.... just make a nice butt cap, winding check and one slip ring (or just make two slip rings with a nice butt cap and winding check). Use a fingernail bit to make the shaped- dado in the wood insert. Most lighter weight rods use slip rings anyway and you wouldn't have to mess with threads. If you were careful and had silver that had a design in it, you might even be able to retain the design on the rings.
  • #65
Just putting this here for future reference. This is what I have left for reel seat inserts I've already turned. Oops, correction, the top row were turned by a wood turner in Australia back in the 90's when we lived there. Dimensionally they aren't as exact as the bottom row, which I turned on my metal lathe. And the top row is NOT stabilized and most have a lacquer finish applied. They still work, even if needing minor sanding. Just wanted to be clear. The bottom row I turned and are all stabilized with Cactus Juice. If someone decides to build a fly rod and is interested in a reel seat insert, left me know. I may hold on to one or two but I probably won't be using these as I haven't made any new fly rods in a couple years now.
Gdurfey
Florissant, CO
Garry
Sorry I missed this Doug…..give me a minute to catch up.
Gdurfey
Florissant, CO
Garry
What can I offer for the ones you are ready to part. The fly fishing club out here has a rod building class that I am signing up for. I have built one rod but have at least 2 blanks to build, maybe more. They have been packed up for way too long. But I would like to offer these other guys possible shot at a few of these.
  • #70
Sorry, missed this post yesterday Garry. I'd be happy to send you 4 or 5 of these. I don't need anything in return, unless you or someone can get access to one of these. It's essentially a three fold "book" you use to make dubbing loops for streamer patterns. I think they're made in Argentina and marketed by a company called Puro Fly. I tried to email them and got no response. I'm toying with the idea of making my own with some 1/16" acrylic and some clear scotch packing tape.
https://purofly.com.ar/493-xa-book-tool.html
Gdurfey
Florissant, CO
Garry
Will be on the lookout for these. I have been following a guy on Instagram that makes his own brushes and has a set up for them. Will look into that.
Thanks, would be honored to fish any of those reel seats.
Mike Hill
Board Whoarder
Nashville, TN
ok, had to peek - that makes sense!
