Some of my work
That segmented bowl is over the top cool! You have a varied style, all of which is appealing. Chuck
Very nice Justin. By the way, it is customary when posting to state what kinds of woods are shown in each of the pictures.
Also, what wood do you mean by zapote? That name is used by at least 70 different species over a couple of dozen different genera
Thanks. I was flying WAY too close to the sun with that one. A chunk of it broke off and hit me in head. The shop teacher drove me to the hospital for glue and bandaids.
The red in these pictures is zapote. I'd give more info, but that's how they are listed at Woodcraft. The rounded one is maple and the tumbling bowl is maple, walnut and cherry. The others are random cast offs from the discount bin.
I really like the segmented piece. I know a lot of us don't always use a face mask BUT WE ALL SHOULD. Glad you are ok.:old:
Justin, beautiful work! That segmented bowl is super cool, glad you survived turning it! Tony
Wow...I love those red ones....
They list it as Zapote (Pouteria sapota), also known as Chico Zapote. That's one I'm not familiar w/.
Not at all common. Most suppliers are questionable, as they often mix descriptions with Manilkara zapota, the tree most commonly tapped in the past for 'chichle' also called chewing gum. I've been looking and have found A. Curtis to be likely the only source of vouchered material, and likely that only in IWCS sample sizes.
Multiple projectiles? :wacko:
Not if you look at the blueprints for the hole in the ceiling tile on the white board above!
What said blue print neglects to point out however, as seen in the picture of the ceiling itself... That's a 10 - 12 foot ceiling, it went through after bouncing off his head!! I'm going to guess 12!!! Top of the windows should be 6'8" so they line up with the tops of doors, if you look at the block work, approximately 8 1/2" per course of block, it's roughly 3 ft. to the top of the ladder, and another 2 ft. above it.
Does that work out to 41 MPH as it hit the tile? Is it refractory or projectual (if on the floor, the first, if in the drop ceiling the second)?
