Steam bending question
Mike1950
Don't know much about steam bending except observation. There is a drum making company here that is unusual in that their drum bodies are of solid, dry wood. They cut to shape and thickness and put a scarf joint on the ends. Then put into a steam box and then bend into a full circle - intense. Every once in a while one cracks. I'm there occassionally buying their scrap - already dry, resawn, milled and sanded thin and sometimes purdy figure. I used to try to get their cracked pieces and they seemed usable - particularly some birdseye maple they had. Lil Mikey thought simple process of soaking the board and putting a heavy weight on it to straighten it. Wrong bucko! I eventually put a couple of anvils on it and it did not straighten! Whatever details they do, they do it right! Anybody needing any slightly curved birdseye maple?
How thin?
Mike Hill
Board Whoarder
Nashville, TN
Have not measured it, but if memory is correct - maybe 3/8". But it does differ with the different types drums they make and the sound they want to make. Thicker wood gives a higher fundamental tone as opposed to the thinner with a lower fundamental tone. Some are up to 1' thick.
Ohh and they use POWER to do the bending after the steam!!!
