Tea box
HSpringsteen
San Diego
Howard
I am new to the group. This is my latest project. A tea box for a friend. It is curly cherry with walnut trim. The inside of the top and bottom are maple veneer.
Very nice Howard. Especially that walnut trim work.
Have you used veneer like that much before? I like the look. But I've always heard veneering one side of a panel can cause issues with glue joints in the long-term.
Thanks Mike.
What I did in this case was I glued a 3/4 piece of cherry to a thin piece 1/8 inch plywood. I glued 3/4 maple to the other side and then cut off the cherry and maple so they were about 3/32 thick. I tried a different method, but it failed miserably. This worked, and we shall see if it holds up.
I like it! Looks simple at first glance. But when you look closer you can tell a lot of work went into this.
Very nicely done, I really like the corner walnut details! Tony
I love the clean lines and the choice of woods...great looking project, hoss!
Beautiful box Howard. Like all our friends above, I love the walnut trim. Superb my friend. Truly superb!
To echo everyone else's comments the clean lines of the walnut really look sharp! Takes the box to a whole different level, great work!
Nicely done Howard. I agree with the fine work on the trim. I also think its worth noting the super clean joints at the corners of that trim and the great job wrapping that grain around the box. Great eye for detail!
Howard, that is a great looking box. I also like the trim job. So much so, I may have to try that on a box I'm in the process of creating right now. At least on the vertical corners.
Nicely done sir.....
