with just enough tension to keep blade straight
This was my first thought. But I wanted an unbiased opinion
I think you would have to compare to new saw- but you are probably right
laguna- I had 14 BX- 2.5 hp- best brake I have had. guides were almost impossible to adjust -no room and I sure did not like sparks. I would not buy a saw again with ceramic guides. replacement guides are very spendy. service sucked.
Hmm. I might have my heart set on a the laguna lt14 suv
try adjusting the guides while at wood craft. My fingers get cramps just thinking about changing blade size. and. they are probably made in same factory with same metal. I think maxed out 14" is the problem. Good luckHmm. I might have my heart set on a the laguna lt14 suv
mine was 2.5 hp BX- plenty of power. I never reawed with it - have 14.5 capability with 21 and more than enough powerI was thinking the 3hp would be nice when I’m resawing 9” wide coco as the 10-326 really struggled
do you have straight edge?Justin, I have the 10-326 bandsaw as well and have never seen this issue that you're having. Have you tried contacting Rikon? I had to contact them once when I broke a part on the fence. They were quite responsive and sent me a new one the next day. I would think they can help you through this.
Damon
I phoned and left a message. I also sent an email.
Any chance you could put a 4’ straight on the back. I’m out 1/4” from being flat.
willing to bet it is bent
