Box pictures-everyones!
Here is box #2. It was built with a purpose in mind. Hickory at 3" wide, 2 1/4" tall and 5 5/8" wide. Edges are 1/4" and the ends are 1/4+.
This is the front side. When the box was made back in 2011, that gap wasn't there. This is store bought KD 8/4 hickory.
Back side.
My problem was that the box shrunk near the outer edges leaving the pith area larger, causing the gap seen in the above pictures and this one. There's a gap at the glue joint that's NOT as visible as seen on the left side. My Iphone is really picking out flaws that aren't as bad as the pictures show. That glue seam and corner on the left are barely visible looking at the actual piece.
The top is flat, but the bottom is where distortion is.
This is the purpose for the box. Black pipe stone from possibly Wisconsin( memory came back). When I was building it, I knew I wasn't going to hinge it, but instead I would drill holes through the edges of the 2 long sides. That way, when the box build was complete, it would be split to give me top and bottom. The holes would align no matter how badly the were drilled. Unfortunately the bit was about 40 thousandths and since Hickory is mean, the bit wandered while drilling. I didn't know until the top was split off from the top. This picture shows how much wandering I had, but the holes aligned.
What I then did was get 18 gunge copper wire and inserted into the bottom part of the box to act as ???? to attach the lid to bottom of the box. It works really well but the left side in this first picture was so close to getting this small job tossed.
Nuttin like kissing a Rattle Snake to get a good toke.
The snake is Mesquite and Palo Verde. I started with a couple pieces if wood 1/2 x 1 3/4 x?. Found center, and then ran a thin kerf groove on both pieces. To verify center, I turned each piece around and ran them again, then glued the pieces together. Shaped the curves and called it quits on that project. I ran a wire through the piece while the glue was still wet to guarantee a good toke.
Enough of this. ................. Nubs
Back side.
Interesting lesson about wood movement! Killer snake!
I bet nobody will be able to tell curly maple from the lowest grade utility timber from home depot (which here is silver fir here). Ah ah ah
Well, if you got some curly silver fir, that might be true. I know I am constantly surprised by folks who tell me they are woodworkers but can't identify much past pine, cedar, or oak. And oak only if it is planed and labeled in the supply house. Our local box store sells oak 1x6x8 (25mm x 150mm x 2.4m) for somewhere north of 60 USD.
I say, stain that silver fir and go for it 😁
One day I will do so. Sometimes it seems that only very few people notice that there are different types of wood - or maybe they just don't care about it.
Finished this one today. Walnut box with cholla lid and accent trim, plus an abalone accent strip. Regular hinges. Maple splines. It is divided into two sections inside and has a lift out tray, also divided into two sections. Took a little extra time to sand and finish all the pieces on this one. Box is around 9x7 x 4 inches deep. I mostly wanted to experiment more with that cholla that Jerry sent me ( thanks Jerry, @Nubsnstubs ).
That is a very good looking box, Doug. The only think I don't like is the cross piece on the inside lid. I think I know why you put it there, but I don't think it was necessary if the reason is to add strength. Beautiful job and you are bringing out what Cholla can do when incorporated with different woods. ............... Nubs
Thanks and you're exactly right Jerry. That panel in the lid is made from two sections of cholla and I glued a small spline the length of the glue joint. It probably didn't need the cross bar but it kept bugging me that someone sometime would put something on top of the box and split the lid. I wasn't worried about the cholla itself, it feels really solid, more that glue joint. Just pretend it isn't there - you only see it when the lid is open.
Duh, I didn't see that those were two pieces of Cholla. It might have looked better going with the seam, but Cholla is pretty stout stuff. What did you use for attaching the strip below the lid? I made about 4-5 picture frames with Cholla as inlay, and filled all the voids with colored fillers and CA. The last frame I rabbetted for the Cholla went fine, but when I started to slice the Cholla into a 1/4 x 3/4' strip, I noticed it had a .223 caliber lead bullett in it and I was lucky as the lead stayed in each piece. One day I'll finish it after I fill all the voids. The lead stays in and will be a highlight. ............ Nubs
Such an original and elegant box! Great use of a variety of materials! Chuck
"What did you use for attaching the strip below the lid?"
That's just more of the same walnut, cut to the same thickness as the lid, notched into each end and sanded smooth. I did glue the cholla panel in place and ran a small bead of glue on that cross bar as well. The accent strips of cholla are 1/8 inch thick by 3/4" wide glued into a matching dado. I think I only had one small corner of the cholla break loose while I was cutting those on my table saw. I glued the cholla strips into place before I mitered the box sides, so the cholla was mitered right along with the walnut without any drama.
In hind sight, the thing that probably doesn't need to be there is the abalone strip. At the time the box seemed a little plain but now that it's done I think I could have skipped the abalone.
You are right about the Abalone strip, but it does not detract from the look at all. The box would have been as nice as it currently is. If I had any sea shell like that, I wood probably do that myself one day. .......... Nubs
The line of where to stop with embellishments is very vague. At best. Usually I have found that I did too much by doing too much... I have box lids to prove it...
I see the walnut in lid, makes sense to me. I love the inlays and the cactus but both, ehhh, beauty is eye of beholder.
Nice box. Good proportions.. maybe in my eye, one bridge too far.
I had this one in the works at the same time as that walnut box. Figured I'd take advantage of having all my tools drug out into the driveway so I cut up the pieces for both boxes at the same time. I've been trying to get these off my bench so I can switch to casting that beetle. Anyway, this one is for a high school classmate of mine, one of the few I stay in touch with and I know she values our time in the Canal Zone as much as I do, so I think she'll appreciate this box. The box itself is made from Florida citrus that Joe ( @wood128 )sold me last year. Not sure what type of citrus but it worked nicely and polishes like glass. The lid is made from mango from Hawai'i ( @Kalai ) framed in louro faia from Brazil. Splines are mahogany. The CZ seal is on a 2" diameter aluminum disc that is coated with a resin. An image is printed on special paper and then impregnated into the resin in a heated press. It's inlayed into the lid using my Dremel to make a matching shallow circle. Very cool process done by a guy with a shop over by the airport. Finish is MinWax wipe on poly, 4 or 5 coats, rubbed out with a micro pad and a light buff with paste wax. Probably one of the best finish jobs I've done. In fact, the whole box came out really really well.
I had this one in the works at the same time as that walnut box. Figured I'd take advantage of having all my tools drug out into the driveway so I cut up the pieces for both boxes at the same time. I've been trying to get these off my bench so I can switch to casting that beetle. Anyway, this one is for a high school classmate of mine, one of the few I stay in touch with and I know she values our time in the Canal Zone as much as I do, so I think she'll appreciate this box. The box itself is made from Florida citrus that Joe ( @wood128 )sold me last year. Not sure what type of citrus but it worked nicely and polishes like glass. The lid is made from mango from Hawai'i ( @Kalai ) framed in louro faia from Brazil. Splines are mahogany. Finish is MinWax wipe on poly, 4 or 5 coats, rubbed out with a micro pad and a light buff with paste wax. Probably one of the best finish jobs I've done. In fact, the whole box came out really really well.
That lid is good. I like the rim especially. It has gorgeous colouration.
Impeccable! All of the components are superior! Chuck
Thanks, and yeah I agree, the colors did work really well - there's just enough orange in the mango that the louro faia brings it out.
Our Town Dump/Recycle Center has an organized area called The Swap Shop where folks are encouraged to leave usable item for others to take. It’s constantly monitored and items are screened to keep junk out. Found this the other day... looks to be hand made by someone with apprentice level skills but was too nice to ignore.
IMG_0592.webp IMG_0593.webp IMG_0594.webp IMG_0595.webp IMG_0596.webp IMG_0597.webp
Besides a wedding ring this is the only jewelry I own and it’s already got a box… will give it to granddaughter next time I see her.
