Such a great idea! My wife & I are big game players, so this will have to go on the to-do list! How did you attach the dividers on the inside of the box? Chuck
I decided to route shallow dados in the inside walls of the box to slide the dividers into. I cut them about half inch shorter than the height of the dividers. Then I cut shallow notches off the end of the divders, so essentially they're hidden dados (if you look closely in the photo of the open box you can see the top of one of the dividers doesn't quite match up to the other. I also cut shallow dados into the long divider to capture the two short dividers.
The sequence of construction was :
1. Cut the sides of the box proper and test fit in the frame clamp. Once I'm satisfied with the box, I figured out how I wanted to use dividers to create the individual sections - e.g. a long narrow one for the dominoes and Yahtzee score pad, a larger square section for the dice cup, and two narrower sections for playing cards and the pencil holder.
2. Measuring from the inside edge of the 45 degree miters, mark where the inside dados go and route them.
3. Sand and finish the interior sides of the box (just easier to do this before gluing it together, but you could do it after gluing.
4. Glue the box sides. Measure and cut dividers from thin plywood.
5. Next build the lid to fit however you want (note, if you're using the hidden pin hinges, you need to make the lid and drill the pins and install the lid at the same time as you glue the box into shape).
6. Oh, for this box, I made the bottom trim, so I cut the rabbets for that before i glued the box together also. So next I cut the bottom trim pieces and carefully fit the 45 degree miters to get a nice clean fit. Glue the bottom trim piece on.
7. Sand and finish the outside of the box. Test fit, sand and finish the dividers and glue them into place (I supposed if your dados are tight you could just let the dividers ride in the dados without glue).
8. Cut shallow dados for the hinges and attach the lid. Drill 1/8" holes and glue in magnets.
9. The bottom trim left room for a piece of plywood for the bottom, so last thing I did was cut and fit that plywood and glue it into place.
