Fourth guitar - Panama Exocet
  • #82
Epoxy fills the pores and the light sanding dulls the surface so it isn't shiny any more. Some luthiers use simple dry wall compound as pore filler- often dyed to match the wood color. You can also buy paste that is sold as pore fillers, most often for furniture makers who want that glassy finish. We like the epoxy because it's easier, less messy, and doesn't build as much residue. A little harder to sand but also less likely to sand through to bare wood again, which can result in a blotchy finish.
  • #83
My guitar coach called me today asking a big favor - he wanted to buy the 000 case I just bought. He sold a left handed cut away he made some time ago and wanted to get it gone so he could get paid. I said sure, just replace it when you can. The timing works great because when I dropped off the case, he inspected the pore fill and gave me the go ahead to start french polishing!! So the body can't be put in a case for some time anyway. I moved one of my mobile work stations inside downstairs, cut a piece of nice clean carpet to cover the top, got my shellac all mixed and filtered (didn't really need to filter but I did anyway), and got my cheese cloth and linen ready to make the applicator pad. So tomorrow I'll start. I'll take some before, during and after pics if anyone is interested.
  • #85
Had an hour or so before the lasagna was done so decided to get started. The french polish technique starts with lots of very thin layers of 1 - 1.5lb cut shellac. The purpose is to begin building a layer of shellac that will later be polished. One of the nice things about this method is you can start and stop at any time. Just remember where you left off - and even that isn't too important at this stage. All I'm trying to do is build a layer of shellac. Obviously the more even it is the better but streaks and stuff aren't a worry at this point. Here's a shot of the back after I started applying the very first few passes of shellac (the left side has shellac, the right does not). It darkens the rosewood a little but I think it really helps bring out the contrast in the grain and between the rosewood and the cocobolo binding.
First coat on left side definitely shows a depth to it. I’ve read up on French polishing, and it is a process not to be rushed, but the results are amazing. Your first photo clearly demonstrates the initial desired results. Excellent! Chuck
  • #87
Starting to build a nice shellac layer now. I think I've put on 5 or 6 pads worth - you fill the pad, squeeze out excess, then lightly wipe on shellac until the pad starts to feel a little dry or it starts to stick. I really like the color of the rosewood. Much lighter than how dark the epoxy pore fill made it look.
I use a video lesson by a guy named O'Brien as my method. He recommends using just the inner pad for this step, which is just cheesecloth. But my cheesecloth must be cheap because I was getting a few tiny filaments and fibers of cloth, so I wrapped my little pad of cheesecloth in linen and used that instead. Later, that same pad will be what I use to level and polish the shellac layer.
That’s beautiful.
  • #89
Making progress. I've built a pretty good shellac layer and am now in the leveling and polishing phases. i level by lightly sanding with 1200 grit and then using pure grain alcohol in my pad, make soft passes, increasing pressure as the pad dries. This melts the shellac and levels it out. I still have some hair streaks you can see in the reflected light so still have more to work on. Then it's on to the top.
That finish is looking amazing. If it sounds as good as it looks you might want to become a luthier.
  • #92
Thanks Daniel, Mike and Chuck and everyone else who's following this. I did one final spiriting off cycle this morning and I think I'm quickly reaching a point of dimensioning returns. I get most of the back pretty smooth but somehow make another few streaks. Then, I do another cycle and those streaks disappear but new ones form elsewhere. I figured out that one thing I was doing was tilting my pad, which allowed the sides of the pad to contact the wood. As the pad dries, the sides especially can get hard and I think they were causing some of the streaks. The last couple cycles I tried hard to keep the pad flat so only the bottom touched the guitar and I think that helped. The sides look pretty good so won't do any more there. This morning's session looks better than the rest so I might stop, let it dry thoroughly and then flip it over and do the top. Then have my coach check it over and tell me "Nope, not good enough, do more."
Really looking good! I get the diminishing returns... but then you stop and find yourself a few months later wishing you'd done just one more round. There is no winning in the self-critique battle, I've found I just have to rely on others' for such critique (they generally don't see a 10th of the flaws I see in my own work).
  • #94
Hard to get a good photo of what I'm trying to show. Here's a couple I took this morning with my regular camera. You can see in the first photo a tiny bit of waviness in the reflected liines. Hopefully you can see what Im' saying about the point of diminishing returns. After we install the bridge, neck and fingerboard, we'll rub it down with a green pad and rub it out using a polishing compound which will help level out the finish a little more and make it not quite so harsh. I didn't get it as clean as sprayed on laquer but got pretty close.
Those are my jars of shellac, bottle of Everclear and the window into my back yard in the reflection.
A few shots of that Everclear and I promise the waviness won't bother you any more!
That is already very good.
  • #98
Working on the top now. Built up a nice shellac layer and have made 6 or 7 leveling / polishing cycles and a couple spiriting off cycles. I had 4 tiny "holes" near the heel where the tape ripped off tiny pieces of the torrified spruce when we did the binding. So I used a needle to dip into the shellac and carefully applied tiny little bubbles of shellac to fill those holes. Let those dry thoroughly and went back to leveling and spiriting off. The holes are gone now (filled with shellac). Probably have a few more cycles of leveling and spiriting off to get the top where I want it. But the torrified spruce has a very cool chatoyance - almost a crystalline look. And the cocobolo rossette is looking awesome too.
This is a champion! Absolutely impressive! Chuck
