2 steps forward one step back
It was pretty critical in the repair of the piece I broke. LOL.Question: Is the I-beam critical to the building procedure or is that just a deception to throw us off?
This is definitely a Rube Goldberg machineToday went a little better than yesterday. After repairing the pieces that I broke yesterday, I reinforced them and then finished off the last pieces needed for the platform. While I was waiting for glue to dry, I started cutting the treads in the tire segments. I finally managed to get the lift assembly platform finished and I managed to get all the treads cut and a couple of wheels glued together. Doesn't look like a lot but I'm pretty pleased with the progress today. At least I didn't break anything. LOL.
View attachment 201737View attachment 201738View attachment 201739View attachment 201740View attachment 201741View attachment 201742
2 steps forward one step back is still 1 step forward...2 steps forward one step back
Well progression is taking place Marc... duh...2 steps forward one step back is still 1 step forward...
They actually turn on them Marc. The dowels were sanded round and then cut to length. They sit in a dado that runs all around the centre hub of the wheels and the tire rolls on the dowel bearings. It's a very cool setup.Ken, do the wheels turn on the dowels? Or is that for looks?
The gears and the rack are made by printing out a pattern of it. I then apply masking tape to the stock and then spray some spray adhesive to the back of the print out and attach it to the masking tape on the stock. At the base of each "cog" I drill a 3/32" hole and then cut the perimeter of the gear (or rack) on the scroll saw. I then use the scroll saw again to cut each tooth in the design.Two questions Ken:
1. How are you making the gears and rack? Do you have a pattern you glue to the wood?
2. If I remember when you admitted this was going to be a dump truck, you said it'll be played with outside. Are you worried about grit and sand getting inside the wheels?
Now I see it!! But, I thought it was supposed to be built in half and then put together.......
