Everything of Paul's is going in this thread. I don't think this piece is thick enough for most carvers. It's only about 1" thick. Might make a nice lightweight tabletop.Any carvers? Butternut is an extremely fine carving wood. Like basswoods better looking cousin. Maybe list it in a separate thread specifically for carvers.
No, there really isn't much in the way of rare species with any of this remaining stock of Paul's. A good chunk of it is US domestic species, though there are still several exotics. There is no rosewood or ebony in Paul's collection. Any rosewoods or ebonies in any package were added from my own stock. There are a few uncommon/oddball species, but they aren't necessarily rare or super valuable. Paul just has some uncommon or less common sizes with some of these pieces, which might be attractive to some.
I was thinking chip carving.Everything of Paul's is going in this thread. I don't think this piece is thick enough for most carvers. It's only about 1" thick. Might make a nice lightweight tabletop.
Sure. I know nothing about that, but I'm sure it could be put to several uses.I was thinking chip carving.
I guess i probably should have weighed all these single pieces ahead of time.And how much does it weigh? ... about 25 lbs?
Yeah. There are areas of woodworking I am clueless about too.Sure. I know nothing about that, but I'm sure it could be put to several uses.
Speaking purely for myself, I almost never make anything larger than 18", and most of my items are 12" or less. I'm perfectly fine with cutting longer boards in any way that's convenient. I'd have to cut up a 48" board myself before using it, in any case. But then, I'm a scrollsawer and not a furniture maker. Other folks may have different needs.I looked through the remaining list of pieces, and several are in the 47-48" length range. I will shave a fraction of an inch off these, as necessary to keep the final package dimensions under 48". This is to avoid an over length surcharge from the carrier.
There are 3 boards that are significantly above 48" length that i didn't want to cut them without getting some feedback. All 3 are Ash, so they aren't high dollar wood. I'm not sure it's it's worth it to pay a surcharge to ship Ash. Alternatively, i could cut them to get below the surcharge limit. Either way, I'm adding another board of my own to bring up the value a little. Thoughts on cutting vs not cutting?
Yeah i think that's the big issue is that you can probably buy white ash at just about any hardwood supplier in the US. I'm not even sure if anyone will want to pay to ship them if i cut them. Maybe ill just take them. I'm not the biggest fan of open grain wood, but i can probably find a use.Cutting vs not cutting: for me it depends on the project on which I'm thinking to use the wood. If it were a cribbage board for example, I'd need min 17 inches long by 4.5 inches wide. If it's a box, I can make the box dimension fit the wood. So for me, unless I know what I'm going to use the wood for, I'd prefer to have the longest piece that's economically reasonable because then I have options. I understand what you're saying about paying shipping premiums for a wood one might be better able to get locally and avoid the extra cost.
