okay here is what went down here in the shop today untill lunch then nap!
the pc is now mounted on a different lathe that accepts the faceplate we like, 1923 oliver from gm tech plant , modernized a bit , complete with homemade plywood pulleys.
ad the final sorta form is made you can see i have left a rather large area unturned to shape , this is on purpose and serves to dampen vibration during the hollowing phase. It will be turned to shape
after the bulk of the pcs is hollow, we just have to bear that in mind .
next you se the steady rest , it is quite stout, and on the really large pcs there are two pcs mirror in design which sandwich the arms of the steady. on large pcs we use 9 arms, on a small one like this one we only need 4 or 5 as you can see
for all you nomenclature nuts yes they are aircraft flap follower bearings, bout 150 $ apeice, but luck for me there is maintainance facility some buds work at and well you know . Oh setting up the steady is a little fussy, if all the arms are not exact right the will cause a catch and that is not good about a thousand pounds of stuff on the lathe spinning now!!!
the last picture is of the forstner bit with the beginning of the drilling process starting with only the chuck The forstner bit is a full 4 inch bit and is serious torque there.
now i am getting ome of the material out of the neck section , this is the most intense section as i am very close to the steady rest and a large pc of spinning wood, the lathe is wagging round a little also through the intermittent cuts
WHEW!
in the previous photo actually two back you can see where the steady has found its orbit with the continual black mark around. That area is also left about an inch proud of neck to absorb the bruising of the bearings and will turn off later. the neck is left very thick as it has a lot riding on it and will be dealt with later. These larger pcs demand a lot of thought and are methodical in the approach. oops ruins about 3000 dollar pc of wood, that we dont want.
homemade drill extensions this one will take us down to 22 inches . we will stop there for the night as danny is whining pretty hard!!!
this is how the pc will look until monday when we get back at it. It is wrapped because it will warp or worse crack if left in open
