- #21
I applied two on the bottom and probably 5 on the top could that be the problem?And did you apply the same finish and same number of coats on the bottom as you did the top?
Probably not the only problem, and might not be a problem at all, but it's always best to do the bottom exactly how you do the top. Doesn't mean you have to sand through the grits the same you just want to keep both sides breathing in and out the same as closely as possible.
Ohh ok I had talked to a local guy for suggestions he said wipe on poly for the top and oil the bottom because of I completely sealed it. It would crack the finish. So I need to finish the whole piece with the same finish same amount?
You're going to get differing opinions, and there are variables. I have had the best results doing as I suggested. Unless you seal the whole thing with a flood coat, the moisture transfer will still happen - if the MC was too high when you did it then yes it can do bad things to the finish and a flood coat won't stop that either - trapped mositure WILL get out somehow.
If it was low say 6% or lower then you shouldn't have a problem. His method will also work in the right conditions and will not cup provided the slab came from in the tree and how large the tree was etc. too many variables to list. As a general rule whatever I do to the top I do to the bottom. Others will tell you different and if it works for them it is not wrong. I am surely not the finsih expert here I am just telling you what works for me.
I figured that- we take a chunk of wood -bolt it to metal frame (show us bottom) - it has been outside- big hunk of wood- we sand and finish it. Put it inside and it is drier wants to shrink Can't because we bolted it to frame underneath and did not let it shrink- so it cracked- all speculative. - Did you allowFor sure not climate controlled!
Bob's your uncle.
for movement in the way bottom metal frame is attached?? My "Guess" is you did not????
I do have an uncle bob I'm guessing this is humor I don't get.
I just put the slab ontop of the frame
It's just sitting on top it's so heavy it doesn't move
That is not safe....
Well obviously I have no clue what I'm doing. Any suggestions? It's on a solid cast iron base with no holes to bolt on
