ah ha! @Kevin is a tablecist. I've seen this before.
I admit it. Tables are inferior.
Austin you are in what professionals call "a quandry" good thing its your father - some lessons are earned the hard way , this is one of them >Austin do not! squander this opportunity to learn a valuable lesson, even if none of us can tell you quite what that lesson is But i thinks you are starting to get it, go boy go I will give u this > either you got big kahunas or you are desparate asking this here bunchWell obviously I have no clue what I'm doing. Any suggestions? It's on a solid cast iron base with no holes to bolt on
either you got big kahunas or you are desparate asking this here bunch![]()
This is close to what I'm referring to
That's exactly what I meant by Z-clip ... now I know the real name for them is "sliding cleat"![]()
I originally wasn't going to take this project on, but was talked into it by my dad. I should of consulted you all in advance for advice. I knew by posting this id get harped on by you all for not doing this properly but when it comes to building something for a client being my father or somebody else. sometimes we have to swallow our pride and ask for help. so i dont know if its being desperate or slightly larger than average kahunas but you gotta do what needs to be done whether you like it or not. thank you a for the help. also as far as a learning experience; I have learned quite a bit from this. one of the things I learned was to not take on projects out of my coffort zone and also to stand up for myself with my opinions. I absolutly hate the base on this table and hated it before we purchased it. but i let my father talk me into it being his table and what he wanted. thanks again for all the help. Im going to wait till winter when the humidity goes down take the slab back to my shop. fill the cracks and take the floor sander to it and re flatten it because it seemed to cup a little bit. a also am going to put some sliding brackets on to secure it and do a few deep dovetails from the bottom to hopefully stop the cracking. lastly sine i need to take the cupping out im going to switch out the finish and seal it better on the bottom so that it will have even moisture flow throughout the piece.
