My boxes
Also avoid over sanding. Corners and edges look a like power sander was used instead of lightly hand sanding. I suspect that due to the amount of wood that was removed.
Have you checked the accuracy of your saw lately? Sometimes they need a fine tuning.
I only use a power sander to remove band saw marks when resawing boards.
I do check my fence alinement regularly.
Most of the time I use my cross cut sleds. One for ninety degrees and one for 45 degrees. I will check those today.
Check accuracy of the sleds too. Cut and flip one side. It should be perfectly straight for a ninety. A 45 should make a perfect 90 and use a square to check it.
Here is another small box.
It is 4 3/4 “ long x 3 5/8” wide x 1 / 1/2“ tall
I believe the body is maple and the lid is the unknown wood.
I made this box while checking the table saw to blade. I also checked the 90 and 45 sleds. All are dialed in. IMG_3237.webp
I made this box while checking the table saw to blade. I also checked the 90 and 45 sleds. All are dialed in. View attachment 293391
View attachment 293392View attachment 293393
The miters are much better. Though, some of your wood seems to be chipped. It seems you need cleaner and clearer pieces of wood. I do think that your main area of improvement should be the hinges. Try out some new ones. These ones look slightly bent and blocky.
Lovely box with greatly improved miters.
The hinge was a cheap one I had laying around. I need to restock my hinges. On my nicer boxes I use to use Brusso hinges but the price of them has gone up to $60. I am on the hunt for a bit cheaper hinges.
Try making rob cosmans hidden hinges. They look cool as hell and are amazing.
Check out quadrant hinges from Rockler. Of course you’ll want the router jig to with them. Perfect for small boxes.
Rick, when routing your pieces, start with the grain about 2-3 inches from an end and go in that direction til the opposite end, continue across the grain and then back to with the long grain. When you finish with the long grain, do the cross grain and then finish with the opposite long grain. What you are basically doing is rotating you piece starting at long grain and finishing with long grain. Guaranteed you will not have tear out on the ends. ................ Nubs
or use a sacrificial push block against the end of the piece you're routing
Thanks. I will try that
Here is my latest box. I really like this wood.
It is made from flame elm. The dimensions are 5 3/4”x5 3/4”x2 3/4” tall.
All was going well with this box until my brain decided to go to Sugar, Honey, Ice Tea today and I made a couple of bad decisions. I decided to suck it up and show it anyway. IMG_3241.webp IMG_3244.webp IMG_3242.webp IMG_3243.webp
It’s very nice. I like the elm. Maybe try making smaller hinges. I like the fact that they are wood but they are a bit large.
I think you're on to something with the wooden hinges. I'd look into how else to attach them so those big screw heads don't show. Even screwed from the inside would be better than showing from the outside. A good glue joint is stronger or at least as strong as the wood itself. Even a wooden dowel sanded flush would be less obtrusive than metal wood screws.
