My boxes
I usually make smaller hinges but they are so fragile. I decided to try thicker ones. I think somewhere in between next time.
Could you post a few close-ups and maybe one or two showing the end grain. I get a strong "Ash" feel when looking at the box, not elm.
There is a street near me that is lined with what they call fire Elm. There was one tree a fire that burned all the moss and scorched the bark. It needed to be completely removed as it was so badly damaged. I happened to go by it and saw some small logs. I asked if I could have it and they said sure. The next day and picked up what I could handle. So yes it is elm.
I think you're on to something with the wooden hinges. I'd look into how else to attach them so those big screw heads don't show. Even screwed from the inside would be better than showing from the outside. A good glue joint is stronger or at least as strong as the wood itself. Even a wooden dowel sanded flush would be less obtrusive than metal wood screws.
I agree. I really messed this one up.
Thanks Rick,
Never heard of fire elm. Must be a local name. Guess it was a massive tree being your box looks to lack any heartwood.
Thanks Rick,
I stand corrected. I just looked it up again and the tree is actually a flame ash tree. Thanks for setting me straight.
Is it this one?
If it is, I'd like to buy 2 samples from you. Looking for a 1/4 sawn sample and a flatsawn sample. Samples finish at 3" wide x 6" long x 1/2" thick. Something a touch bigger would be great so I can work it and get a feel for the wood after it seasons.
Here is my latest box. The body and lid is made from Alder that has been in the shop for years. The lift out tray is some more of the unknown wood I like so much. The dimensions are 8 5/8” x 4 3/4” x 3” tall.
I tried a new hinge from wood craft (Hipoint) since Brusso hinges have gotten ridiculously expensive. I am pleased with them and will continue to use them.
The finish is two coats of Danish oil and buffed out with a clear wax. IMG_3255.webp IMG_3256.webp IMG_3258.webp
The finish is two coats of Danish oil and buffed out with a clear wax. View attachment 293858View attachment 293859View attachment 293860
Good work. That top is surprisingly nice for alder.
Really like this one! Alder is primo.
Here is my next box. It is made from flame Ash. The dimensions are 5 3/4”x 5 3/4” x2 1/4”tall. The finish is Watco oil and buffed out with a clear hard wax. The hinges are small antique brass.
The interesting thing about this box was when I made the original lid and sanded it up it turned almost a light pink with very little grain pattern. The second one came out just like I wanted with all the figure showing. IMG_3270.webp IMG_3269.webp IMG_3271.webp IMG_3272.webp IMG_3273.webp
The interesting thing about this box was View attachment 294122when I made the original lid and sanded it up it turned almost a light pink with very little grain pattern. The second one came out just like I wanted with all the figure showing. View attachment 294123View attachment 294124
Pink is a common color to find in many members of the ash family. It often fades and dissapears.
That is very good. The simpler wood types make your technique more visible. Looks good here.
So here is the first flame ash box revamped.
I ditched the wooden hinges and re- shaped the front. I added small small brass hinges
The dimensions are 5 1/2”x5 3/4”x 2 1/8” tall.
Finish is Watco oil and buffed out with clear wax.
